[postgis-tickets] [PostGIS] #2751: [extension] 2.1.3 from unpackaged: ERROR: function _st_asraster(...) does not exist
PostGIS trac at osgeo.org
Wed May 28 10:01:43 PDT 2014
not exist
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.4
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 I'm getting this error trying to create 2.1.3 extension from unpackaged:
 ERROR:  function _st_asraster(geometry, double precision, double
 precision, integer, integer, text[], double precision[], double
 precision[], double precision, double precision, double precision, double
 precision, double precision, double precision, boolean) does not exist
 The postgis_full_version() function detects no problem and tells me I'm at
 2.1.3. The rtpostgis_upgrade_21_minor.sql runs successfully.
 Still the mentioned (over-parametrized) _st_asraster() function is still
 found missing on CREATE FROM unpackaged.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2751>
