[postgis-tickets] [PostGIS] #2982: Crashing on PostgreSQL9.5 dev on topology
PostGIS trac at osgeo.org
Thu Nov 6 09:47:06 PST 2014
 Reporter:  robe            |       Owner:  strk
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS PostgreSQL
Component:  topology        |     Version:  trunk
 Keywords:  postgresql 9.5  |
Comment(by robe):
 Okay this test that doesn't involve postgis at all seems to crash also
 which points the finger at 9.5:
 CREATE OR REPLACE FUNCTION crash_test(table_name varchar, column_name
 varchar)
   RETURNS bigint AS
 DECLARE
  var_result bigint;
 BEGIN
        EXECUTE 'ALTER TABLE ' || quote_ident(table_name) || ' ADD COLUMN '
 || quote_ident(column_name) || ' text;';
        var_result = (random()*100000)::bigint;
        RETURN var_result;
 END
   LANGUAGE plpgsql VOLATILE
   COST 100;
 DROP TABLE IF EXISTS test_1;
 CREATE TABLE test_1(id serial primary key);
 DROP TABLE IF EXISTS test_crash;
 CREATE TEMP TABLE test_crash AS
 SELECT 1 As id, crash_test('test_1', 'lyr1') As layer;
 INSERT INTO test_crash(id, layer)
 SELECT id + 1, crash_test('test_1', 'lyr' || (id + 1)::text)
 FROM test_crash
 WHERE id = 1;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2982#comment:10>
