[postgis-tickets] [PostGIS] #2986: [raster] raster2pgqsql
PostGIS trac at osgeo.org
Sat Nov 8 04:18:15 PST 2014
 Reporter:  rmorelli     |       Owner:  dustymugs
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.5
Component:  raster       |     Version:  2.1.x
 Keywords:               |
Comment(by robe):
 rmorelli -- I think there should be a way to escape text.  I don't like
 this workaround because there are other cases where people will want to do
 text filters.
 I know I mentioned the above.  Have you tried using:
 '' as an escape.  That's the new way of escaping in PostgreSQL and the \'
 was a legacy way which may be turned off in new PostgreSQL.
 So syntax would be:
  DATA "PG:host=localhost port=5432 dbname='xxx' user='xxx' password='xxx'
 schema='raster' table='dem' where='filename=''dem20_12.tif''' mode='2'"
 Also you above was missing an apostrophe so wouldn't have worked anyway --
 might have been my fault when I sent to postgis-users I might have left
 out the other slash
 So correct using slashes would be
 schema='raster' table='dem' where='filename=\'dem20_12.tif\'' mode='2'"
 I don't like this proposes since it seems more a work around to something
 that is either an issue or just a misunderstanding with the GDAL driver.
 I'd much prefer updating the documentation to reflect how to use strings.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2986#comment:1>
