[postgis-tickets] [PostGIS] #2986: [raster] raster2pgqsql
PostGIS trac at osgeo.org
Mon Nov 10 07:43:44 PST 2014
 Reporter:  rmorelli     |       Owner:  dustymugs
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.5
Component:  raster       |     Version:  2.1.x
 Keywords:               |
Comment(by robe):
 I just tried using gdal_translate (packaged with 6.5dev from here
 http://www.gisinternals.com/sdk/)
 (http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1600-gdal-
 mapserver.zip)  which should be in theory similar command as what
 Mapserver uses for loading postgis raster
 gdal_translate -of jpeg PG:"host='localhost' port='5432'
 dbname='somedb' user='postgres' password='whatever' schema='aerials'
 table='o_2_boston' where='filename=\'22528915.sid.jpg\' ' mode='2'"
 and this worked fine on PostGIS 2.1.3, PostgreSQL 9.2 database.  So maybe
 something with mapserver then.  Will take me longer to set that up, but at
 least doesn't seem anything wrong with latest gdal (and I'm pretty sure
 I've used similar older gdal to do those exports).  Can you if not too
 much trouble turn logging on your database and include output of query
 mapserver is running.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2986#comment:8>
