[postgis-tickets] [PostGIS] #2986: [raster] raster2pgqsql
trac at osgeo.org
Mon Nov 10 09:08:38 PST 2014
Reporter: rmorelli | Owner: dustymugs
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.5
Component: raster | Version: 2.1.x
Keywords: |
Comment(by robe):
The gdal_translate error is probably because its looking in raster_columns
and can't find useful meta data (though the table should be registered in
that view but probably with not any useful information -- do you see it
listed in raster_columns view).
I did run AddRasterConstraints on my table with the -C option during load,
but you should have similar issues using a number for file if you are
getting that. Does gdal_translate work with your integer id?
Anyrate to get rid of that as documented here: http://postgis.net/docs
/manual-dev/RT_AddRasterConstraints.html
SELECT AddRasterConstraints('raster', 'dem', 'rast');
now it looks like mapserver is stripping off the escape \ making the gdal
query invalid
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2986#comment:11>
