[postgis-tickets] [PostGIS] #2989: Debbie failing on interrupt test
PostGIS trac at osgeo.org
Tue Nov 11 01:17:03 PST 2014
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  assigned
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 I found all the cases had in common to be the first one running, while the
 timer started before creating the input tables. Resetting the timer right
 before execution of the test should be more stable. Committed as r13124.
 Please close if that's enough.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2989#comment:5>
