[postgis-tickets] [PostGIS] #2989: Debbie failing on interrupt test
PostGIS trac at osgeo.org
Tue Nov 11 04:49:08 PST 2014
  Reporter:  robe     |       Owner:  strk
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Debbie seems to be good.  Winnie is still complaining but her current
 issue seems to have nothing to do with this (and she did run a successful
 run just before your very last commit).  Rerunning hers to see if issue
 goes away, which I think it will.  Closing this out for now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2989#comment:7>
