[postgis-tickets] [PostGIS] #2992: winnie regress failures on raster tests
PostGIS trac at osgeo.org
Fri Nov 14 13:37:56 PST 2014
 Reporter:  robe     |       Owner:  robe
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Changes (by robe):
  * owner:  strk => robe
Comment:
 I was wrong it was this one that broke it: r13123
  Revision 13125 by strk:
 Do not expect DO responses in raster regress
 Fixes testsuite broke by r13123
 The file was modified
 /trunk/raster/test/regress/permitted_gdal_drivers_expected
 /trunk/raster/test/regress/rt_elevation_functions_expected
 The file was modified   /trunk/raster/test/regress/rt_mapalgebra_expected
 so seems the run_test.pl change perhaps winnie is ignoring.  I'll try to
 do a fresh svn pull
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2992#comment:2>
