[postgis-tickets] [PostGIS] #2989: Debbie failing on interrupt test
PostGIS trac at osgeo.org
Sun Nov 16 14:54:20 PST 2014
  Reporter:  robe     |       Owner:  strk
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment(by robe):
 strk sorry.  Although debbie complains much less often she still complains
 about this every so often like in her GDAL Postgres runs and her
 PostgreSQL Dev weekly runs.  In those she may be more taxed because she
 recompiles GDAL and recompiles PostgreSQL and then does the tests.
 Here is what her 9.5 development run looked like:
  interrupt .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_63_diff)
 --- interrupt_expected  2014-11-15 20:10:13.000000000 -0800
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_63_out
 2014-11-15 20:16:18.000000000 -0800
 @@ -1,4 +1,4 @@
  NOTICE:  liblwgeom code interrupted
  ERROR:  canceling statement due to statement timeout
 -segmentize interrupted on time
 +segmentize interrupted late: 00:00:00.188626
  1|LINESTRING(0 0,2 0,4 0)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2989#comment:9>
