[postgis-tickets] [PostGIS] #2995: invalid access to memory location
PostGIS trac at osgeo.org
Mon Nov 17 10:59:18 PST 2014
 Reporter:  robe        |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  high        |   Milestone:  PostGIS 2.1.5
Component:  postgis     |     Version:  2.1.x
 Keywords:  windows 64  |
 This may be a duplicate of #2476 and could even be a windows 64 specific
 issue. I'm not tagging it as raster this time though cause I'm not sure
 its raster.
 Leo has managed to trigger this error:
 To be a bit annoying.  One is a nightly process he runs which he was able
 to get around the issue by changing the order of the steps in his process.
 The only thing odd about his process is his unorthodox use of PostGIS
 (converting times to geometries so he could use geometry intersection and
 aggregate functions).
 The other was just geocoding some data.
 Neither invoived using any raster functions.  I haven't quite pinpointed
 what could be the issue, but he's managed to trigger the problem on two
 separate Windows 64-bit boxes (one running Windows 2012 R1 and another
 Windows 2008 R2)
 But same version of PostgreSQL / PostGIS:
 POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" RASTER PostgreSQL 9.3.5, compiled by Visual C++ build
 1600, 64-bit
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2995>
