[postgis-tickets] [PostGIS] #3002: ST_GeomFromGeoJSON() Causes postgres to crash
PostGIS trac at osgeo.org
Sat Nov 22 01:08:04 PST 2014
 Reporter:  vannut   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.5
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 When executing a query which uses 'ST_GeomFromGeoJSON()' the backend
 crashes and you need to reconnect.
 This simple query crashes:
 SELECT
 ST_GeomFromGeoJSON('{"type":"Point","coordinates":[-48.23456,20.12345]}'));
 When using gdb to track whats going on, I can see this in the output:
 Program received signal SIGSEGV, Segmentation fault.
 0xb70dda59 in _IO_vfprintf_internal (s=0xbfde7150, format=<optimized out>,
 ap=0xbfde7298 "") at vfprintf.c:1630
 1630    vfprintf.c: No such file or directory.
 I'm using postgis 2.1.4 r12966 and a postgresql 9.3.5 server.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3002>
