[postgis-tickets] [PostGIS] #3002: ST_GeomFromGeoJSON() Causes postgres to crash
PostGIS trac at osgeo.org
Tue Nov 25 06:41:20 PST 2014
 Reporter:  vannut   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.5
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Comment(by robe):
 Mine works fine too running on windows 9.3 64-bit.
 SELECT
 ST_GeomFromGeoJSON('{"type":"Point","coordinates":[-48.23456,20.12345]}');
              st_geomfromgeojson
  01010000009279E40F061E48C0F2B0506B9A1F3440
 (1 row)
 {{{SELECT postgis_full_version();
 POSTGIS="2.1.4 r12966" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.11.0, released 2014/04/16" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" TOPOLOGY RASTER
 SELECT version();
                            version
  PostgreSQL 9.3.5, compiled by Visual C++ build 1600, 64-bit
 Regarding the LIBJSON version not showing, PostGIS only shows the JSON
 version if you are running LIBJSON 0.11 and above as I recall so the fact
 it doesn't show is not an issue.  You probably do want to check what
 version yours was compiled with.
 Actually I'm not even sure if we show the libjson version in PostGIS 2.1
 for any version of LIBJSON (I think we do, but mine doesn't but my json
 version might be too low).  Brian is cheating cause he's running a
 development version of both PostgreSQL and PostGIS :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3002#comment:5>
