[postgis-tickets] [PostGIS] #3002: ST_GeomFromGeoJSON() Causes postgres to crash
PostGIS trac at osgeo.org
Tue Nov 25 13:32:01 PST 2014
 Reporter:  vannut   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.5
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Comment(by pramsey):
 The root our *our* crash problem was library version mismatch. The build
 system was using 0.9, but I was deploying on a system with 0.11. The RPM
 packages only declared their requirement as "json-c" without any version
 specificity. Apparently json is not forward binary compatible, so
 packagers beware: you have to peg your json-c version in your package
 dependency declarations.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3002#comment:8>
