[postgis-tickets] [PostGIS] #3003: Will just not compile anymore on FreeBSD 10.1
PostGIS trac at osgeo.org
Thu Nov 27 17:57:59 PST 2014
 Reporter:  martin5519  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  high        |   Milestone:  PostGIS 2.1.5
Component:  postgis     |     Version:  2.1.x
 Keywords:              |
 I've tried everything.  I have a bug open at:
 https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=195090
 We've been developing software with Postgis as a module and had zero
 problems before. Since almost 2 weeks now, we've been unable to reinstall
 following two hard drive crashes.  I've tried 2 different FreeBSD ports
 and I've tried compiling from source with 2.0.6 and 2.1.4.  In the ports
 version, I've even fixed 2 errors (undeclared json_tokener variable and
 link to json/json.h should be json-c/json.h).
 Anyhow,  I know it's a free module and it's terrific but I'm just getting
 really frustrated.  I'm even offering to pay or donate - will someone,
 PLEASE help me.. tell me your hourly rate, just log into my system and
 see.
 At first I thought it was a FreeBSD port problem (well, it has been as
 well) but I'm having issues from Source as well.  I have the EXACT version
 of all dependencies install required.  Whether it's me or it's a valid
 issue, I really need some help here.   The error is always the same (port
 or from source):
 Makefile:103: recipe for target 'shp2pgsql' failed
 gmake[2]: *** [shp2pgsql] Error 1
 gmake[2]: Leaving directory '/usr/home/martin/postgis-2.0.6/loader'
 GNUmakefile:14: recipe for target 'all' failed
 gmake[1]: *** [all] Error 1
 gmake[1]: Leaving directory '/usr/home/martin/postgis-2.0.6'
 *** Error code 2
 Worse part is I don't even need shp2pgsql but I can't seem to remove it as
 an option.
 Martin
 p.s. I have not tried 2.1.5..
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3003>
