[postgis-tickets] [PostGIS] #3003: Will just not compile anymore on FreeBSD 10.1
PostGIS trac at osgeo.org
Fri Nov 28 09:01:41 PST 2014
 Reporter:  martin5519  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  high        |   Milestone:  PostGIS 2.1.5
Component:  postgis     |     Version:  2.1.x
 Keywords:              |
Comment(by martin5519):
 Ok, here's the Pastebins.  I believe in open source but it's hard for me
 to contribute as I am not a programmer.  Therefore let me know anything I
 can do to contribute here.
 Make install clean from port version 21
 http://pastebin.com/hALMbGvD
 From Source Version 2.1.4  - CONFIGURE:
 http://pastebin.com/c7rvbuFk
 From Source Version 2.1.4 - MAKE
 http://pastebin.com/LHfTHxJV
 After having done these above, I tried the following:
 root at database:~martin/postgis-2.1.4/liblwgeom # cd .libs
 root at database:~martin/postgis-2.1.4/liblwgeom/.libs # ls
 liblwgeom.a     liblwgeom.la    liblwgeom.lai
 root at database:~martin/postgis-2.1.4/liblwgeom/.libs # cd ..
 root at database:~martin/postgis-2.1.4/liblwgeom # cp -r libs libs.back
 root at database:~martin/postgis-2.1.4/liblwgeom/.libs # rm -rf *
 Then I tried a make clean and make from source again - same output as
 above from what I can see: http://pastebin.com/LHfTHxJV - from source.
 Martin
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3003#comment:4>
