[postgis-tickets] [PostGIS] #3003: Will just not compile anymore on FreeBSD 10.1
PostGIS trac at osgeo.org
Sun Nov 30 05:06:38 PST 2014
 Reporter:  martin5519  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  high        |   Milestone:  PostGIS 2.1.5
Component:  postgis     |     Version:  2.1.x
 Keywords:              |
Comment(by martin5519):
 Well, I'm not expert and your issue is different than mine but for yours,
 look at this:
 cp ../../doc/tiger_geocoder_comments.sql
 sql_bits/tiger_geocoder_comments.sql
 388     cp: ../../doc/tiger_geocoder_comments.sql: No such file or
 directory
 389     Makefile:132: recipe for target
 'sql_bits/tiger_geocoder_comments.sql' failed
 390     gmake[3]: *** [sql_bits/tiger_geocoder_comments.sql] Error 1
 Seems like a file is missing from source?  But why the issue just on
 FreeBSD?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3003#comment:13>
