[postgis-tickets] [PostGIS] #3003: Will just not compile anymore on FreeBSD 10.1
PostGIS trac at osgeo.org
Sun Nov 30 20:28:28 PST 2014
 Reporter:  martin5519  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  PostGIS 2.1.5
Component:  postgis     |     Version:  2.1.x
 Keywords:              |
Comment(by robe):
 Bah I thin the comment issue may be the same as what Nicklas ran into
 here:
 http://lists.osgeo.org/pipermail/postgis-devel/2014-September/024549.html
 which strk fixed in r13012
 http://lists.osgeo.org/pipermail/postgis-devel/2014-September/024552.html
 and PostGIS 2.1.4 was at r12966
 So it's quite possible the comments issue existed in 2.1.4 and I missed it
 because I don't have a clean install.
 That would also explain why on my Ubuntu I have 2.1.4 but it seems to be
 using the 2.1.3 scripts.  Anyway as Martin says his issue is different and
 he'll eventually run into this one once he fixes his libm issue.  I'll
 ticket as a separate ticket.
 If it is indeed an issue -- we need to rush out a 2.1.5 before PostgreSQL
 9.4 hits release (and they are at RC1) so not much time.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3003#comment:17>
