[postgis-tickets] [PostGIS] #2948: Build broken by latest ST_ClipByBox2D commit
PostGIS trac at osgeo.org
Wed Oct 1 05:51:00 PDT 2014
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Changes (by robe):
  * owner:  pramsey => strk
Old description:
> Both winnie and debbie are registering this error:
> lwgeom_geos_node.lo lwgeom_geos_node.c
> libtool: compile:  gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes
> -I/var/lib/jenkins/workspace/geos/rel-3.4.3devw64/include -c
> lwgeom_geos_node.c  -fPIC -DPIC -o .libs/lwgeom_geos_node.o
> lwgeom_geos_node.c: In function ‘lwgeom_extract_unique_endpoints’:
> lwgeom_geos_node.c:98: error: too few arguments to function ‘LWGEOM2GEOS’
> lwgeom_geos_node.c: In function ‘lwgeom_node’:
> lwgeom_geos_node.c:149: error: too few arguments to function
> ‘LWGEOM2GEOS’
> make[1]: *** [lwgeom_geos_node.lo] Error 1
> make[1]: Leaving directory
> `/var/lib/jenkins/workspace/postgis/branches/2.2/liblwgeom'
> make: *** [all] Error 1
> winnie compiles 2.2 against GEOS 3.5 trunk and debbie against GEOS 3.4
> branch
New description:
 since r13018
 lwgeom_geos_node.c:149: error: too few arguments to function ‘LWGEOM2GEOS’
 branch
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2948#comment:1>
