[postgis-tickets] [PostGIS] #2949: Memory leaks test_mindistance2d_tolerance
PostGIS trac at osgeo.org
Wed Oct 1 06:59:17 PDT 2014
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.5
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Changes (by strk):
  * priority:  medium => blocker
Comment:
 The problem is with lwcurvepoly_construct_from_lwpoly, partially
 allocating new memory (for "rings") and partially copying pointer from
 input memory (bbox). Cloning the box and using lwgeom_release from the
 callers fixes it.
 Committed as 13021 in trunk (2.2.0) and r13022 in 2.1 branch (2.1.5)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2949#comment:2>
