[postgis-tickets] [PostGIS] #2950: Make ST_ClipByBox2D interruptible
PostGIS trac at osgeo.org
Wed Oct 1 15:38:48 PDT 2014
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 I've found inputs that make ST_ClipByBox2D stuck, and attempts to
 interrupt it eventually crashes the backend.
 It's some geometries in the gadm4 dataset.
 Those with cartodb_id=5 in the gadm4 test created as part of Windshaft-
 CartoDB tests.
 This is probably a GEOS issue, anyway the symptom bubbles up here so I'm
 marking it as a blocker here (GEOS-3.5.0 isn't out yet)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2950>
