[postgis-tickets] [PostGIS] #2093: Add extra policy argument to control ST_Simplify behavior
PostGIS trac at osgeo.org
Thu Oct 2 02:13:33 PDT 2014
 Reporter:  robe         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by strk):
 So, current policy is:
  - lines: never collapse (this was not included in the previous attempt at
 giving policies, but it is to always keep at least 2 points, the first and
 the furthest)
  - polygon shells: null
  - polygon holes: remove
 So the proposed set of policies increases by adding a "do not allow
 collapses" for lines.
 I guess the equivalent for polygons (do not allow collapses) might also be
 useful, for both shells and holes. Ideally it would be composed by the
 first/last point + the farther from them + the farther from the segment
 composed by the previous two (for DP).
 Also, I was thinking that "topological invalid" is really never useful to
 be intentional, that is since  you have to keep at least 2 points for
 lines and 4 points for rings, they may as well be not topologically
 invalid (and a minimum number of points in output is likely to give you a
 valid return).
 So the possible policies become:
  - collapsed line: null, single vertex line, 2 vertices line [1], a point
  - collapsed shell: null [1], single vertex ring, 4 vertices ring, a line
 or point
  - collapsed hole: removed [1], single vertex ring, 4 vertices ring
 [1] current behavior
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2093#comment:18>
