[postgis-tickets] [PostGIS] #2953: Unable to compute stats for some features
PostGIS trac at osgeo.org
Thu Oct 2 10:34:52 PDT 2014
  Reporter:  pramsey  |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 2.1.5
 Component:  postgis  |     Version:  2.1.x
Resolution:  fixed    |    Keywords:  stats
Changes (by pramsey):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I put in a different, more "correct" solution at r13030 on trunk, r13031
 on 2.1.
 Rather than force the box into a "valid" space in all cases, I just trip
 the higher dimensions when in the 2d mode. This results in good stats for
 2d, and bad stats of n-d, which fixes 95% of the use cases. If you're
 building an nd-index on this crazy Z/M data, then you can deal with the
 badness.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2953#comment:2>
