[postgis-tickets] [PostGIS] #2954: ST_ClipByBox2D: ERROR: gbox_overlaps: cannot compare geodetic and non-geodetic boxes
PostGIS trac at osgeo.org
Fri Oct 3 01:47:36 PDT 2014
geodetic boxes
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 It's worst: the actual results depend on some previous state.
 MEMORY FAULT HIDING !
 =# SELECT st_clipbybox2d('SRID=4326;POINT(0 0)','BOX3D(-1 -1,1
 1)'::box3d::box2d);
 0101000020E610000000000000000000000000000000000000
 1)'::box3d);
 1)'::box3d::box2d);
 Note that the first (succeeding) and last (failing) queries are identical.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2954#comment:2>
