[postgis-tickets] [PostGIS] #2955: ST_AsGML is missing some protos
PostGIS trac at osgeo.org
Sat Oct 4 17:04:44 PDT 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.5
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 I just noticed that the most common proto versions of ST_AsGML have been
 remarked out.  Not sure why that was done and when it was done, but I'm
 putting them back.
 These two were remarked out:
         <funcprototype>
                                 <funcdef>text
 <function>ST_AsGML</function></funcdef>
                                 <paramdef><type>geometry </type>
 <parameter>geom</parameter></paramdef>
                                 <paramdef choice="opt"><type>integer
 </type> <parameter>maxdecimaldigits=15</parameter></paramdef>
 </type> <parameter>options=0</parameter></paramdef>
                         </funcprototype>
                         <funcprototype>
                                 <funcdef>text
                                 <paramdef><type>geography </type>
 <parameter>geog</parameter></paramdef>
                         </funcprototype>
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2955>
