[postgis-tickets] [PostGIS] #2962: debbie erroring on 2.2 doc building
PostGIS trac at osgeo.org
Fri Oct 10 09:13:42 PDT 2014
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 It's failing on the po2xml.  One thing I had done was do a simulate clean
 checkout to try to fix the issue.  I think before I had some stale Italy
 and Brazil files which got wiped out.  so perhaps that is triggering the
 issue.  We might be missing some PO files.  I wonder if that is what is
 causing the transifex recent alerts too of can't find this .po.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2962#comment:6>
