[postgis-tickets] [PostGIS] #2964: ST_OffSetCurve returns EMPTY geometries and other issues
PostGIS trac at osgeo.org
Mon Oct 13 02:21:31 PDT 2014
 Reporter:  drbullit        |       Owner:  pramsey
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.1.5
Component:  postgis         |     Version:  2.1.x
 Keywords:  st_offsetcurve  |
 First issue is that when using negative offset values, st_offsetcurve
 returns an EMPTY geometry in some cases.
 Reference geometry:
 LINESTRING(-76.941839 38.915428,-76.941883 38.915476,-76.94189 38.915497)
 Both st_astext(st_offsetcurve(geom, -15)) and
 st_astext(st_offsetcurve(geom, -1)) return LINESTRING EMPTY
 Positive offset values do not return empty geometries, but do seem to
 affect length of the geometry. I was under the assumption these result
 geometries would only be 'shifted parallelly' not see significant geometry
 changes:
 original geometry length -- st_length(geom, true) --> 4879.15614361318
 result of st_length(st_offsetcurve(geom, 1),true) -->
 168892.068090029
 SRID of original geometry is 4326
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2964>
