[postgis-tickets] [PostGIS] #2965: ST_Distance, use_spheroid default
PostGIS trac at osgeo.org
Mon Oct 13 06:08:01 PDT 2014
 Reporter:  gitai                      |       Owner:  pramsey
     Type:  defect                     |      Status:  new
 Priority:  critical                   |   Milestone:  PostGIS 2.1.5
Component:  postgis                    |     Version:  2.1.x
 Keywords:  ST_Distance, use_spheroid  |
Comment(by gitai):
 hmm.. new to postgis .. very confusing..
 http://postgis.net/docs/manual-dev/ST_MakePoint.html
 1. "Note x is longitude and y is latitude"
    --Return point marked as WGS 84 long lat
 2. SELECT ST_SetSRID(ST_MakePoint(-71.1043443253471,
 42.3150676015829),4326);
 Seems very dangerous .. Search the internet and you will see that
 ST_MakePoint is very popular method to quickly create points for params
 for geography calculations.. I guess people rely on the autocast.
 BTW, Is there a way to create a geography in PostGIS without cast?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2965#comment:2>
