[postgis-tickets] [PostGIS] #2974: ST_ConvexHull is uninterruptible
trac at osgeo.org
Thu Oct 23 08:34:46 PDT 2014
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS GEOS
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by strk):
A memory-friendlier example (takes around 5.2GB of RAM max):
time psql -f - <<EOF
set statement_timeout to 5000; -- 5 seconds
select
st_npoints(st_convexhull(st_collect(ST_Segmentize(ST_Rotate(ST_MakeLine(ST_MakePoint(0+x,
0),ST_MakePoint(400+x,400)), radians(x%180)), 1)))) from
generate_series(0,100000) x;
EOF
The above runs in 52 seconds, while the timeout asked for a max of 5
seconds (you may need to allow for a slightly longer run in order to enter
the ST_ConvexHull part).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2974#comment:4>
