[postgis-tickets] [PostGIS] #2975: ST_Intersects with a LineString and MultiPolygon crashes PostgreSQL
PostGIS trac at osgeo.org
Thu Oct 23 12:04:42 PDT 2014
 Reporter:  royseto                     |       Owner:  pramsey
     Type:  defect                      |      Status:  new
 Priority:  high                        |   Milestone:  PostGIS 2.1.5
Component:  postgis                     |     Version:  2.1.x
 Keywords:  st_intersects crash memory  |
 ST_Intersects with a LineString that has 52229 points and a MultiPolygon
 that has 509 points exhausts all the memory on our PostgreSQL server until
 the database crashes. On our server with 72GB of memory, this happens in
 20-60 minutes.
 I am attaching a test case with the LineString and MultiPolygon encoded as
 HEX WKB text files. It includes a SQL version of the test case as well as
 a standalone test case that calls GEOSIntersects() from the GEOS C API.
 PostgreSQL version:
 PostgreSQL 9.3.5 on x86_64-unknown-linux-gnu, compiled by gcc
 (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3, 64-bit
 PostGIS full version:
 POSTGIS="2.1.4 r12966" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.11.1, released 2014/09/24" LIBXML="2.7.8"
 LIBJSON="UNKNO
 WN" RASTER
 OS: Ubuntu 12.04
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2975>
