[postgis-tickets] [PostGIS] #2965: ST_Distance, use_spheroid default
PostGIS trac at osgeo.org
Fri Oct 24 06:44:48 PDT 2014
  Reporter:  gitai     |       Owner:  pramsey
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.1.5
 Component:  postgis   |     Version:  2.1.x
Resolution:  wontfix   |    Keywords:  ST_Distance, use_spheroid
Comment(by gitai):
 Replying to [comment:17 robe]:
 >So the fact you happened to waltz into the right geography function when
 passing your geometries in is nothing we can  protect you from short of
 removing the autocast ...
 Which is exactly the scope of the ticket ... I'm not familiar with source
 to hold a discussion as to why removing the autocast from ST_Distance
 requires also removing autocast from all other functions, which appears to
 be why this issue is rejected, but probably there is reason..
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2965#comment:18>
