[postgis-tickets] [PostGIS] #2982: Debbie crashing on PostgreSQL9.5 dev on topology
PostGIS trac at osgeo.org
Sat Oct 25 22:13:30 PDT 2014
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  PostGIS 2.2.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 Debbie crashed during her weekly regress of PostgreSQL 9.5 snapshot.
  regress/st_simplify .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_26_diff)
 --- regress/st_simplify_expected        2014-04-26 22:51:51.000000000
 -0700
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_26_out
 2014-10-25 20:18:11.000000000 -0700
 @@ -3,7 +3,7 @@
  N2
  S1|f|t
  S2|f|t
 -L2
 -HS1|f|t
 -HS2|f|t
 -f
 +server closed the connection unexpectedly
 +       This probably means the server terminated abnormally
 +       before or while processing the request.
 +connection to server was lost
 --- regress/topoelement_expected        2014-04-26 22:51:51.000000000
 -0700
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_27_out
 @@ -1,6 +1 @@
 -1|{101,1}
 -2|{101,2}
 -3|{101,3}
 -4|{1,104}
 -ERROR:  value for domain topoelement violates check constraint
 "lower_dimension"
 "type_range"
 +psql: FATAL:  the database system is in recovery mode
  regress/topoelementarray_agg .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_28_diff)
 --- regress/topoelementarray_agg_expected       2014-04-26
 22:51:51.000000000 -0700
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_28_out
 @@ -1,2 +1 @@
 -1|{{1,3}}
 -2|{{4,1},{5,2}}
 There are a bunch more others but I suspect that was because she was in
 recovery mode.  I'm going to run again just to see if it was a fluke of
 nature.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2982>
