[postgis-tickets] [PostGIS] #2983: something funky with the interrupt test when regress with extension
PostGIS trac at osgeo.org
Sun Oct 26 22:18:30 PDT 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 On my local machine, I tried regressing with:
  make check RUNTESTFLAGS=--extension
 When I run the regress tests against my 9.4beta3, GEOS 3.5.0 dev, the make
 check gets hung on
  interrupt ..
 I went to bed and work up and it was still stuck there. I had to Ctrl X-C
 to get it to continue with the other tests.
 This is running with:
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis
 PostgreSQL 9.4beta3, compiled by Visual C++ build 1800, 64-bit
  - 2014-09-27 06:44:04
   scripts 2.2.0dev r13000
   GEOS: 3.5.0dev-CAPI-1.9.0 r4026
   PROJ: Rel. 4.8.0, 6 March 2012
 The issue doesn't seem to happen if I regress without the
 RUNTTESTFLAGS=--extension
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2983>
