[postgis-tickets] [PostGIS] #2983: something funky with the interrupt test when regress with extension
PostGIS trac at osgeo.org
Sun Oct 26 23:57:45 PDT 2014
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by darkblueb):
 Linux Ubuntu 14.04 also hangs:
 Upgrading PostGIS in 'postgis_reg' using: ALTER EXTENSION postgis UPDATE
 TO '2.2.0devnext'
 PostgreSQL 9.4beta3 on x86_64-unknown-linux-gnu, compiled by gcc (Ubuntu
 4.8.2-19ubuntu1) 4.8.2, 64-bit
 Checking for shp2pgsql ... found
 Checking for pgsql2shp ... found
 TMPDIR is /tmp/pgis_reg
 Creating database 'postgis_reg'
 Preparing db 'postgis_reg' using: CREATE EXTENSION postgis
   Postgis 2.2.0dev - r13102 - 2014-10-21 18:04:36
   scripts 2.2.0dev r13102
   GEOS: 3.4.3dev-CAPI-1.8.3 r4020
   PROJ: Rel. 4.8.0, 6 March 2012
  out_geometry .. ok
  out_geography .. ok
  in_geohash .. ok
  in_gml .. ok
  in_kml .. ok
  in_encodedpolyline .. ok
  interrupt ..
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2983#comment:2>
