[postgis-tickets] [PostGIS] #2983: something funky with the interrupt test when regress with extension
PostGIS trac at osgeo.org
Tue Oct 28 00:29:59 PDT 2014
  Reporter:  robe     |       Owner:  strk
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:  invalid  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 No. The tests were using an older installed version. Once I copied the new
 install version it worked fine so closing out as invalid.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2983#comment:4>
