[postgis-tickets] [PostGIS] #2920: ST_Union(raster): ERROR: rt_raster_from_two_rasters: The two rasters provided do not have the same alignment
PostGIS trac at osgeo.org
Tue Sep 2 02:25:15 PDT 2014
 Reporter:  strk      |       Owner:  dustymugs
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.1.4
Component:  raster    |     Version:  2.1.x
 Keywords:            |
 The PostGIS manual does not say anything about ST_Union argument need to
 be aligned:
 http://postgis.net/docs/RT_ST_Union.html
 But ST_Union() errors out complaining about the provided rasters not being
 aligned here:
 WITH inp AS (
  SELECT
 '0100000100000000000000104000000000000010C00000000000003E4000000000000044C00000000000000000000000000000000000000000030003004400000000000000000000'
 ::raster r
 UNION ALL SELECT
 '0100000100000000000000104000000000000010C00000000000003E4000000000000049C00000000000000000000000000000000000000000030003004400000000000000000000'
 ::raster
 SELECT ST_Union(r) FROM inp;
 Is it a bug in the implementation or in the manual ? I'd guess the former.
 The rasters metadata show they have the same scale, size and upper-left X
 ordinate, while Y ordinate is 10 units apart (not representable with a
 pixel height of 4):
 strk=# WITH inp AS (
  SELECT
 ::raster r
 UNION ALL SELECT
 ::raster
 SELECT (ST_Metadata(r)).* FROM inp;
  upperleftx | upperlefty | width | height | scalex | scaley | skewx |
 skewy | srid | numbands
          30 |        -40 |     3 |      3 |      4 |     -4 |     0 |
 0 |    0 |        1
          30 |        -50 |     3 |      3 |      4 |     -4 |     0 |
 0 |    0 |        1
 (2 rows)
 Failure is both in trunk and 2.1.4dev r12924.
 Tested with "GDAL 2.0.0dev, released 2014/04/16"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2920>
