[postgis-tickets] [PostGIS] #2920: [raster] ST_Union(raster): ERROR: rt_raster_from_two_rasters: The two rasters provided do not have the same alignment
PostGIS trac at osgeo.org
Tue Sep 2 08:42:00 PDT 2014
 Reporter:  strk           |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  high           |   Milestone:  PostGIS 2.1.4
Component:  documentation  |     Version:  2.1.x
 Keywords:                 |
Changes (by strk):
  * owner:  dustymugs => robe
  * priority:  critical => high
  * component:  raster => documentation
Comment:
 Looking up the manual for "alignemnt" issues I found:
  - ST_MapAlgebraExpr2 will make the _output_ have the alignment of the
 first argument (meaning the input do not need to be aligned, right ?):
 http://postgis.net/docs/RT_ST_MapAlgebraExpr2.html
  - ST_SameAlignment short description does not mention offset as being
 part of the definition (in the detailed description there is more):
 http://postgis.net/docs/RT_ST_SameAlignment.html
 .. more things to look at
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2920#comment:4>
