[postgis-tickets] [PostGIS] #2922: missing postgis.control
PostGIS trac at osgeo.org
Wed Sep 3 02:15:12 PDT 2014
 Reporter:  martinl                |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.4
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:  postgis.control        |
Comment(by strk):
 Check the output of ./configure, make sure that extensions are enabled
 (could be disabled due to missing dependencies).
 If extensions are enabled, check the output of "make install", see where
 the postgis.control file gets installed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2922#comment:1>
