[postgis-tickets] [PostGIS] #1265: no ID for constraint linkend: PostGIS_Geometry_DumpFunctions
PostGIS trac at osgeo.org
Wed Sep 3 02:28:49 PDT 2014
  Reporter:  strk           |       Owner:  robe
      Type:  defect         |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS Future
 Component:  documentation  |     Version:  trunk
Resolution:  invalid        |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Found: the postgis_aggs_mm.xml file was empty. Removing that file and
 calling "make html" again resulted in a correct build, with no more
 warnings.
 I verified (in 2.0, 2.1 and trunk branches) that "make clean" does get rid
 of the postgis_aggs_mm.xml. Closing as invalid.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1265#comment:6>
