[postgis-tickets] [PostGIS] #2925: raster: ST_AsPNG does not support 2BUI. Potential regression
PostGIS trac at osgeo.org
Sun Sep 7 09:53:07 PDT 2014
 Reporter:  robe    |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.2.0
Component:  raster  |     Version:  2.1.x
 Keywords:          |
 I'm not 100% sure, but I think when I created the 2BUI example way back in
 2.0, it worked
 http://postgis.net/docs/manual-2.1/RT_ST_AsRaster.html
 I try with 2.1.3 and it says raster has to be '8BUI'.
 Not a big deal I guess I can just correct the docs, I just wasn't sure if
 it should be flagged as a regression change.  I don't have 2.0 setup at
 moment to test.  I suppose it could be GDAL specific too since I was
 testing with 1.8 back then.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2925>
