[postgis-tickets] [PostGIS] #2697: ST_GeomFromGeoJSON() of invalid GeoJSON Polygons crashes server process, possibly corrupts shared memory
PostGIS trac at osgeo.org
Tue Sep 9 03:46:09 PDT 2014
  Reporter:  kochb    |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  high     |   Milestone:  PostGIS 2.1.3
 Component:  postgis  |     Version:  2.1.x
Resolution:           |    Keywords:  history
Changes (by tusharahuja):
 * cc: tusharahuja (added)
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 This issue is reproducible on postGIS 2.0.6 against PG 9.2.9 (Linux32/64)
 --PG Version
 postgres=# select version();
                                                 version
  PostgreSQL 9.2.9 on i686-pc-linux-gnu, compiled by gcc (GCC) 4.5.1
 20100924 (Red Hat 4.5.1-4), 32-bit
 (1 row)
 --postGIS version -
 postgres=# select postgis_full_version();
  POSTGIS="2.0.6 r12554" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March
 2012" LIBXML="2.7.7" LIBJSON="UNKNOWN"
 (1 row)
 --crash Query -
 postgres=# SELECT '#2697',
 ST_GeomFromGeoJSON('{"type":"Polygon","coordinates":[1]}');
 The connection to the server was lost. Attempting reset: WARNING:
 terminating connection because of crash of another server process
 DETAIL:  The postmaster has commanded this server process to roll back the
 current transaction and exit, because another server process exited
 abnormally and possibly corrupted shared memory.
 HINT:  In a moment you should be able to reconnect to the database and
 repeat your command.
 Failed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2697#comment:9>
