[postgis-tickets] [PostGIS] #2247: [raster] Create ST_CreateOverviews()
PostGIS trac at osgeo.org
Thu Sep 11 09:12:25 PDT 2014
 Reporter:  dzwarg             |       Owner:  strk
     Type:  enhancement        |      Status:  assigned
 Priority:  medium             |   Milestone:  PostGIS 2.2.0
Component:  raster             |     Version:  trunk
 Keywords:  raster, overviews  |
Comment(by strk):
 About the extent parameter of the ST_Retile function: the use case for
 specifying one is to use different processes to retile different portions
 of the table. Especially useful for big coverages.
 If you want a single process you can either find the extent in the
 raster_columns view or compute it using st_extent(rast).
 Allowing for a null (or omitted) extent could be an added facility, but as
 ST_CreateOverview is an easier-to-use wrapper to it already I'm not sure
 we need a more user-oriented signature in ST_Retile.
 I agree about reducing parameter names (besides, those name are big pain
 in general as any name change requires a DROP of the old function...).
 About regclass, the advantage is that you get a single value to univoquely
 identify a table. There's an implicit cast from 'unknown' (inputted text)
 and 'regclass' so you usually just name your table, with or without schema
 qualification, and PostgreSQL does the rest for you, making use of the
 search_path exactly as done when using normal sql. Very useful. I love
 that type. Learning new things is annoying, I know, but once you look it
 up, you're going to like it. It's not going anywhere. From a usage point
 of view you may consider it just a text representing your table, with
 values like 'mytab' or '"MyMixedCaseSchema"."MyMixedCaseTable"'. Maybe the
 PostGIS manual could contain a page that talks about this "regclass"
 type...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2247#comment:30>
