[postgis-tickets] [PostGIS] #2918: Use GeographicLib functions for ST_Azimuth, ST_Distance and ST_Project
PostGIS trac at osgeo.org
Tue Sep 16 04:25:06 PDT 2014
 Reporter:  mwtoews  |       Owner:  pramsey
     Type:  patch    |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by mwtoews):
 More performance and precision results ....
 = Test data =
 First, the `testgeod` table has been updated from yesterday.
 drop table testgeod;
 create unlogged table testgeod (
   id serial primary key,
   lat1 numeric, -- degrees
   lon1 numeric, -- always 0
   azi1 numeric, -- azimuth, in degrees
   lat2 numeric,
   lon2 numeric,
   azi2 numeric,
   s12 numeric,  -- distance, in metres
   a12 numeric,
   m12 numeric,
   "S12" numeric,  -- area under the geodesic, in square metres
   geog1 geography(Point,4326),
   geog2 geography(Point,4326),
   polyg geography(Polygon,4326),  -- Karney (2013) Fig. 1, quadrilateral
 AFHB
   area double precision,
   azimuth double precision,
   distance double precision,
   e real, -- first eccentricity: circle is zero, one is thin
   antipode_fraction real
 copy testgeod (lat1, lon1, azi1, lat2, lon2, azi2, s12, a12, m12, "S12")
 from '/path/to/GeodTest.dat'
 delimiter ' ';
 update testgeod set
   geog1 = ST_MakePoint(lon1, lat1)::geography,
   geog2 = ST_MakePoint(lon2, lat2)::geography,
   polyg = ST_MakePolygon(ST_MakeLine(
     ARRAY[ST_MakePoint(lon1, lat1), -- A
           ST_MakePoint(lon1, 0),    -- F
           ST_MakePoint(lon2, 0),    -- H
           ST_MakePoint(lon2, lat2), -- B
           ST_MakePoint(lon1, lat1)])),  -- close with A
   area = abs("S12"),
   azimuth = radians(azi1),
   distance = s12,
   e = case when abs(lat1 - lat2) < abs(lon1 - lon2)
            then sqrt(1 - pow(lat1 - lat2, 2)/pow(lon1 - lon2, 2))
            else sqrt(1 - pow(lon1 - lon2, 2)/pow(lat1 - lat2, 2)) end,
   antipode_fraction = s12 / 20003931.459;
 The test column `e` ("first eccentricity" of the bounds) is used to tell
 very thin quadrilaterals (1.0) to roundish (0.0). The `antipode_fraction`
 is near 0.0 for short geodesics, and 1.0 for ones that are 180°. These are
 necessary to filter out some end-member tests for fair comparisons with
 Vincenty's algorithms. The test data has a wide mixture of geodesics,
 including a number of corner cases like near-antipodes. Please keep this
 in mind for both interpretations for both timings and analysis of
 precision distributions, as they are probably biased against Vincenty's.
 = Direct geodesic calculation (`ST_Project`) - update =
 The only change is to avoid casting `s12` from numeric, and just use
 `distance` (double precision).
 drop table if exists f;
 select id, st_project(geog1, distance, azimuth) into unlogged f from
 testgeod;
 This boots the performance of each test to 1871 ms vs 2742 ms, or 1.46
 times slower for Karney.
 The precision results are the same as before, but to describe the %
 accuracy at a few other arbitrary cutoffs:
 select
   avg(case when diff_distance <= 1e-2 then 100 else 0 end)::numeric(8,2)
 || '%' as cm,
   avg(case when diff_distance <= 1e-3 then 100 else 0 end)::numeric(8,2)
 || '%' as mm,
   avg(case when diff_distance <= 1e-6 then 100 else 0 end)::numeric(8,2)
 || '%' as µm,
   avg(case when diff_distance <= 1e-8 then 100 else 0 end)::numeric(8,2)
 || '%' as ten_nm
 from (
   select st_distance(st_project, geog2) as diff_distance
   from f join testgeod g on g.id=f.id
 ) as f;
 ||Method|| 1 cm || 1 mm || 1 µm || 10 nm ||
 ||Vincenty||100.00%||96.33%||28.05%||24.90%||
 ||Karney||100.00%||100.00%||100.00%||99.98%||
 = Inverse geodesic calculations =
 == Azimuth ==
 Test performance of `ST_Azimuth`:
 select id, st_azimuth(geog1, geog2) into unlogged f from testgeod;
 With these tests, Karney's is 3 times faster than Vincenty's, which is the
 opposite of what I've found earlier, and I think it is due to the dataset
 which has challenging geodesics that require more iteration with
 Vincenty's. Compare 11384 ms to 3786 ms for Karney's.
 Test accuracy of `ST_Azimuth`:
 select f.id, s12, antipode_fraction, e, degrees(st_azimuth) as
 st_azimuth_degrees, azi1,
   (((degrees(st_azimuth) - azi1 + 180.0)::numeric % 360.0) - 180.0) as
 diff_degrees
 -- where antipode_fraction between 0.004 and 0.996
 order by abs(((degrees(st_azimuth) - azi1 + 90.0)::numeric % 180.0) -
 90.0) desc
 limit 10;
 With the near-antipodes included (no filter), compare maximum absolute
 errors 89.992633730349° to 0.031697236597° error. Removing the comment to
 apply the filter to remove near-antipodes, compare 0.000006260972° to
 0.000000000003°. And the % within precision table:
 select
   avg(case when diff_degrees <= 90 then 100 else 0 end)::numeric(8,3) ||
   avg(case when diff_degrees <= 1e+0 then 100 else 0 end)::numeric(8,3) ||
   avg(case when diff_degrees <= 1e-3 then 100 else 0 end)::numeric(8,3) ||
   avg(case when diff_degrees <= 1e-6 then 100 else 0 end)::numeric(8,3) ||
   avg(case when diff_degrees <= 1e-9 then 100 else 0 end)::numeric(8,3) ||
   avg(case when diff_degrees <= 1e-12 then 100 else 0 end)::numeric(8,3)
   avg(case when diff_degrees <= 1e-15 then 100 else 0 end)::numeric(8,3)
 from (
   select
     abs(((degrees(st_azimuth) - azi1 + 180.0)::numeric % 360.0) - 180.0)
 as diff_degrees
 ) as f;
 ||Method||90°||1°||1e-3°||1e-6°||1e-9°||1e-12°||1e-15°||
 ||Vincenty||91.675%||89.842%||84.959%||78.527%||73.551%||32.790%||31.574%||
 ||Karney||100.000%||100.000%||99.995%||86.328%||82.551%||61.332%||57.107%||
 == Distance ==
 Test performance of `ST_Distance`:
 select id, st_distance(geog1, geog2) into unlogged f from testgeod;
 The results are essentially the same for azimuth, since they use the same
 underlying methods.
 For the accuracy:
 select f.id, s12, antipode_fraction, e, distance, st_distance,
   (st_distance - distance) as diff_distance
 order by abs(st_distance - distance) desc
 limit 10;
 errors 133912.525 m to 1.49e-8 m error. Removing the comment to apply the
 filter to remove near-antipodes, the error of Vincenty's reduces to
 0.01953874 m, and Karney's remains the same, at 14.9 nm. And the % within
 precision table:
 select
   avg(case when diff_distance <= 1e+5 then 100 else 0 end)::numeric(8,3)
   avg(case when diff_distance <= 1e+3 then 100 else 0 end)::numeric(8,3)
   avg(case when diff_distance <= 1e+0 then 100 else 0 end)::numeric(8,3)
   avg(case when diff_distance <= 1e-3 then 100 else 0 end)::numeric(8,3)
   avg(case when diff_distance <= 1e-6 then 100 else 0 end)::numeric(8,3)
   avg(case when diff_distance <= 1e-8 then 100 else 0 end)::numeric(8,3)
   avg(case when diff_distance <= 1e-9 then 100 else 0 end)::numeric(8,3)
 from (
   select
     abs(st_distance - distance) as diff_distance
 ) as f;
 ||Method|| 500 km || 1 km || 1 m || 1 mm || 1 µm || 10 nm || 1 nm ||
 ||Vincenty||99.659%||97.404%||96.400%||65.387%||19.603%||6.425%||3.135%||
 ||Karney||100.000%||100.000%||100.000%||100.000%||100.000%||99.873%||58.909%||
 == Area ==
 The geodesic test data use a the quadrilateral AFHB (Fig. 1, Karney 2013),
 which is area under the geodesic to the equator. Unfortunately, the
 current algorithm in PostGIS cannot use points in the same hemisphere
 ("ERROR:  ptarray_area_spheroid: cannot handle ptarray that crosses
 equator"), so only 325088 tests or 65.02% can be used. Here are the
 performance tests:
 select id, st_area(polyg) into unlogged f from testgeod
 where (lat1 > 0 and lat2 < 0) or (lat1 < 0 and lat2 > 0);
 The performance is identical, about 1950 ms. I think I need to dig around
 a bit more to find out why, as I'm seeing really odd behaviour. This
 Polygon has a NaN area for both unpatched and patched:
 select ST_Area('POLYGON((0 78.703946026663,0 0,179.999997913235
 0,179.999997913235 -33.0888306884702,0 78.703946026663))'::geography);
 Looking at the debug messages, it seems to be happy to calculate the dot
 product instead of the area
 NOTICE:  [lwgeom.c:lwgeom_set_srid:1499] entered with srid=4326
 NOTICE:  [lwgeom.c:lwgeom_is_empty:1277] lwgeom_is_empty: got type Polygon
 NOTICE:  [lwgeodetic.c:edge_point_side:655] dot product 3.64209202e-08
 NOTICE:  [lwgeodetic.c:edge_point_side:655] dot product -3.97170884e-09
 NOTICE:  [lwgeom_transform.c:PROJ4SRSCacheDelete:139] deleting projection
 object (0x7f35d11ba360) with MemoryContext key (0x7f35d11d8c10)
 whereas with `select ST_Area('POLYGON((0 0, 1 1, 1 0, 0 0))'::geography)`
 the messages in this location are:
 NOTICE:  [lwspheroid.c:ptarray_area_spheroid:143] geod_polygon_addpoint 1:
 1 1
 NOTICE:  [lwspheroid.c:ptarray_area_spheroid:143] geod_polygon_addpoint 2:
 0 1
 NOTICE:  [lwspheroid.c:ptarray_area_spheroid:143] geod_polygon_addpoint 3:
 0 0
 NOTICE:  [lwspheroid.c:ptarray_area_spheroid:151] geod_polygon_compute
 area: -6154854786.72
 so why the dot product instead of ptarray_area_spheroid?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2918#comment:15>
