[postgis-tickets] [PostGIS] #2933: Speed up ST_GeomFromWKB
PostGIS trac at osgeo.org
Fri Sep 19 23:53:43 PDT 2014
 Reporter:  strk         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by strk):
 The check is to protect from coding errors as it ensures caller did not
 pass the same pointer twice (which would result in an ownership conflict).
 Can be safely disabled by default, maybe based on a PARANOIA_LEVEL macro
 so that debuggers can raise the panic.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2933#comment:9>
