[postgis-tickets] [PostGIS] #2942: topology not compatible with latest 9.5 dev
PostGIS trac at osgeo.org
Sun Sep 28 10:48:32 PDT 2014
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.2.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Description changed by robe:
Old description:
> Debbie just screamed in her weekend 9.5 run.  It seems they changed
> something in 9.5 code base that is incompatible with topology.  Probably
> a bit too early to be alarmed but we should keep an eye on it.
> psql:/var/lib/jenkins/workspace/postgis/regress_pgdev/branches/2.2/regress/00
> -regress-install/share/contrib/postgis/topology.sql:382: NOTICE:
> constraint "type_range" of domain "topology.topoelement" does not exist,
> skipping
> -regress-install/share/contrib/postgis/topology.sql:2667: ERROR:  too
> many parameters specified for RAISE
> CONTEXT:  compilation of PL/pgSQL function "intersects" near line 201
New description:
 something in 9.5 code base that is incompatible with topology.  Probably a
 -regress-install/share/contrib/postgis/topology.sql:2667: ERROR:  too many
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2942#comment:1>
