[postgis-tickets] [PostGIS] #2942: topology intersects function not compatible with latest 9.5 dev
PostGIS trac at osgeo.org
Mon Sep 29 09:18:22 PDT 2014
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  blocker   |   Milestone:  PostGIS 2.1.5
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by robe):
 She only tests 9.5 on weekends after pulling down rebuilding the latest
 PostgreSQL 9.5 dev tar ball --
 is the job http://debbie.postgis.net:8080/job/PostGIS_Regress_PGDEV_Weekly
 which you can manually trigger (if you log in :) ) or if you can't
 remember your login I can retrigger when you are ready.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2942#comment:9>
