[postgis-tickets] [PostGIS] #2760: geocoder producing erronous results
PostGIS trac at osgeo.org
Mon Sep 29 09:30:32 PDT 2014
 Reporter:  infinityedge  |       Owner:  robe
     Type:  defect        |      Status:  new
 Priority:  medium        |   Milestone:
Component:  postgis       |     Version:  2.1.x
 Keywords:  geocoder      |
Comment(by robe):
 Did you install the Nation Script?
 http://postgis.net/docs/manual-2.1/Loader_Generate_Nation_Script.html
 That was the main change between 2.0 and 2.1 -- they started having
 counties as a single file -- so changed the logic to load up all these
 nation files apart from state.  If you missed this step then you will get
 very bad results.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2760#comment:3>
