[postgis-tickets] [PostGIS] #2944: ERROR: aggregate st_astwkbagg(geometry, integer, bigint, boolean) does not exist
PostGIS trac at osgeo.org
Tue Sep 30 09:30:49 PDT 2014
exist
 Reporter:  strk     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 The problem with that is you could still get an error upgrading from a dev
 version to another revision of the same dev version while having views
 relying on aggregates. Is that ok to keep ?
 The alternative would be to include revision number in the availability
 tag...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2944#comment:4>
