[postgis-tickets] [PostGIS] #3095: raster2pgsql ignores srid, outdb empty
PostGIS trac at osgeo.org
Fri Apr 3 05:56:20 PDT 2015
  Reporter:  martinl  |       Owner:  dustymugs
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.1.7
 Component:  raster   |     Version:  2.1.x
Resolution:  invalid  |    Keywords:  raster2pgsql
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 You are reading raster_columns table.  That gets populated by constraints.
 You need to add the -C to your load to make that populate right.
 If you just want to confirm your srid is set do
 SELECT ST_SRID(rast)
 from dmt LIMIT 1
 Please post future questions like this not to our bug tracker, but to
 users mailing list
 http://lists.osgeo.org/mailman/listinfo/postgis-users
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3095#comment:1>
