[postgis-tickets] [PostGIS] #2227: Visvalingam line generalization function
PostGIS trac at osgeo.org
Fri Apr 3 15:36:17 PDT 2015
 Reporter:  strk         |       Owner:  nicklas
     Type:  enhancement  |      Status:  new
 Priority:  blocker      |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by nicklas):
 ST_SimplifyVW added in r13417 and r13418
 and I found several bugs in the minheap implementation. There is now a
 test in the code that errors if minheap doesn't return points in right
 order. But now I have tested in quite a lot of data and it seems to behave
 as it should.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2227#comment:23>
