[postgis-tickets] [PostGIS] #3096: PostgreSQL 9.5 regress failure raster
PostGIS trac at osgeo.org
Sun Apr 5 00:08:23 PDT 2015
 Reporter:  robe     |       Owner:  dustymugs
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  raster   |     Version:  trunk
 Keywords:           |
 Debbie's weekly run of PostgreSQL 9.5 failed again.
 This time different of course.
 Details here, I will output the specific raster failures
 rt_createoverview .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_53_diff)
 --- rt_createoverview_expected  2014-09-06 20:09:58.000000000 -0700
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_53_out
 2015-04-04 20:08:33.000000000 -0700
 @@ -1,15 +1,11 @@
  t
 -t
 -t
 -t
 -t
 -res1|r|0|1|-1|10|10|t|t|t|t|t|t
 -o_2_res1|r|0|2|-2|10|10|t|t|t|t|t|t
 -o_4_res1|r|0|4|-4|10|10|t|t|t|t|t|t
 -o_8_res1|r|0|8|-8|10|10|t|t|t|t|t|t
 -o_16_res1|r|0|16|-16|10|10|t|t|t|t|t|t
 -o_2_res1|r|res1|r|2
 -o_4_res1|r|res1|r|4
 -o_8_res1|r|res1|r|8
 -o_16_res1|r|res1|r|16
 -count|544|136|36|10|3
 +ERROR:  invalid input syntax for type double precision: "'-1'"
 +ERROR:  relation "o_2_res1" does not exist at character 74
 +ERROR:  table "o_16_res1" does not exist
 +ERROR:  table "o_8_res1" does not exist
 +ERROR:  table "o_4_res1" does not exist
 +ERROR:  table "o_2_res1" does not exist
  loader/Basic .... failed (testdiff expected obtained:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_79_diff)
 --- loader/Basic.select.expected        2015-01-24 20:05:28.000000000
 -0800
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_79_out
 2015-04-04 20:08:36.000000000 -0700
 @@ -1,4 +1,4 @@
 -0|1.0000000000|-1.0000000000|90|50|t|f|3|{8BUI,8BUI,8BUI}|{NULL,NULL,NULL}|{f,f,f}|POLYGON((0
 -50,0 0,90 0,90 -50,0 -50))
  POLYGON((0 0,1 0,1 -1,0 -1,0 0))|255
  POLYGON((89 -49,90 -49,90 -50,89 -50,89 -49))|0
  POLYGON((44 -24,45 -24,45 -25,44 -25,44 -24))|0
  loader/Projected .... failed ( test: running raster2pgsql output:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/loader.err)
 BEGIN
 psql:/var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/loader.out:2:
 ERROR:  relation "loadedrast" already exists
  failed (Errors while running sql script loader/Projected-post.sql:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/test_80_tmp)
 TRUNCATE TABLE
 ERROR:  table "o_2_loadedrast" does not exist
  ... but cleanup sql failed! loader/BasicCopy ... failed ( test: running
 BEGIN
  loader/BasicFilename ... failed ( test: running raster2pgsql output:
 BEGIN
  loader/BasicOutDB ... failed ( test: running raster2pgsql output:
 BEGIN
  loader/Tiled10x10 ... failed ( test: running raster2pgsql output:
 BEGIN
  loader/Tiled10x10Copy ... failed ( test: running raster2pgsql output:
 BEGIN
  loader/Tiled8x8 ... failed ( test: running raster2pgsql output:
 BEGIN
  clean .. ok
  uninstall .
 /var/lib/jenkins/workspace/postgis/regress_pgdev/branches/2.2/regress/00
 -regress-install/share/contrib/postgis/uninstall_rtpostgis.sql
  failed (Error encountered loading
 -regress-install/share/contrib/postgis/uninstall_rtpostgis.sql:
 /var/lib/jenkins/workspace/postgis/regress_pgdev/tmp/2_2_pg9.5w64/regress_log)
 createlang: language "plpgsql" is already installed in database
 "postgis_reg"
 I assume this one is coming from upgrade test:
 psql:/var/lib/jenkins/workspace/postgis/regress_pgdev/branches/2.2/regress/00
 -regress-install/share/contrib/postgis/uninstall_rtpostgis.sql:70: ERROR:
 cannot drop function st_envelope(raster) because other objects depend on
 it
 DETAIL:  constraint enforce_max_extent_rast on table loadedrast depends on
 HINT:  Use DROP ... CASCADE to drop the dependent objects too.
 make[3]: *** [check] Error 1
 make[3]: Leaving directory
 `/var/lib/jenkins/workspace/postgis/regress_pgdev/branches/2.2/raster/test/regress'
 make[2]: *** [check] Error 2
 make[2]: Leaving directory
 `/var/lib/jenkins/workspace/postgis/regress_pgdev/branches/2.2/raster/test'
 make[1]: *** [check] Error 2
 make[1]: Leaving directory
 `/var/lib/jenkins/workspace/postgis/regress_pgdev/branches/2.2/raster'
 Anyway it seems all raster this time.  Last week was fine and since our
 other PostgreSQL versions are doing fine, I can only assume it's a change
 in PostgreSQL 9.5 code base.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3096>
